Separate color corrections can also be saved and loaded using the Once a preset is applied, you can use the Save current channel ( ) button to save the image in the format of your choice.
buttons....
Separate color corrections can also be saved and loaded using the buttons. Once a preset is applied, you can use the Save current channel (
