UI Expand
titleUI Path: ||Select V-Ray Volume Grid|| > Command panel > Modify panel tab > Grid rollout
width60%
Cell Size – Specifies the size of voxels along each axis.
– Specifies the number of voxels along the X axis.
Y – Specifies the number of voxels along the Y axis.
– Specifies the number of voxels along the Z axis.
Increase Resolution – Increases the number of voxels along each axis, thus decreasing the cell size.
Decrease Resolution – Decreases the number of voxles voxels along each axis, thus increasing the cell size
width5%
width35%
