changes.mady.by.user Gergana Lilkova
Saved on Aug 14, 2020
Saved on Jul 01, 2021
Use File – Enable to use a Python post-translate file.
File – Add Adds a Python post-translate file.
Use Script – Enable to use a Python post-translate script.
Script (Python) – Add Adds a Python post-translate script.
File – Shows the number of post-translate files.
Add – Add Adds another instance.
Delete– Remove Removes last instance.
Clear – Clear Clears all instances.
Remove – Removes a post-translate file.
Insert Before – Inserts a post-translate file before the current file.
Use – Enable to use the post-translate file.
File (*.py) – Add Adds a post-translate file.
