width50%
The VRayMtlOSL material can be used to load OSL shader code files (.osl) or OSL object code files (.oso) and render them directly with V-Ray.
UI Paths:
||mat Network|| > V-Ray > Material > V-Ray OSL Material
||out Network|| > V-Ray Render Elements node node > V-Ray > Material > V-Ray OSL Material
width5%
width25%45%
Image RemovedImage Added
width50%
OSL Source – Specifies whether the OSL shader code is inserted inline or loaded through a file.
Inline OSL – The OSL shader code is inserted inline.
File path (.oso/.osl) – The OSL shader code is loaded through a file.
Path to .oso/.osl file – Specifies the path to the OSL shader code file.
width5%
width45%
Fancy Bullets
typecircle
