Floatingpagetoc
CSS Stylesheet
.rwui_text_box {
margin:0px;
Responsivegridmacro
VAlignmentstart
Columns3width1290px
Columns1width1540px
Columns2width1290px
This page provides information on the Live Link feature from SketchUp in Chaos Vantage.
UI Text Box
typewarning
Live Link is currently in experimental phase.
The Live Link feature makes it possible to instantly see changes made in a V-Ray compatible DCC SketchUp without the need to export and import .vrscenes in Chaos Vantage.
Live Link Setup
For Live Link to function properly please follow the steps below:
Installation
UI Text Box
typenote
Live Link works only with officially released V-Ray 5 versions or stable nightly builds.
width50%
1. Download and install latest official V-Ray 5 for 3ds MaxSketchup build from the download button. Make sure you have appropriate licenses. If you experience problems please contact Chaos Support using the online form.
width5%
width45%
Align
alignright
UI Button
colorblue
newWindowtrue
icondownload
titleDownload VRay 5 for 3ds MaxSketchUp
urlhttps://downloadhttps://download.chaosgroup.com/?platform=4956&product=47
2.1 Install Chaos Vantage. Make sure in the advanced section in the installer you have Install V-Ray for 3ds Max Live Link option enabled. It automatically installs the Live Link from Sketchup option, Export and send the .vrscene to Chaos Vantage, as well as the Import Changes from Chaos Vantage tools compatible with 3ds Max versions 2019, 2020 and 2021.
width50%
2. Download latest Chaos Vantage build from the download button. Make sure you have appropriate licenses. If you experience problems please contact support@chaosgroup.com Chaos Support using the online form.
width5%
width45%
Align
alignright
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Chaos Vantage
urlhttps://download.chaosgroup.com/?platform=47&product=63
width50%
UI Text Box
typenote
The Live Link scripts are automatically installed with V-Ray 5 for 3ds Max, update 1 and later.
width5%
width45%
Align
alignright
Image Removed
After installation Live Link can be initiated by either of 2 ways:
Initiate Live Link to Vantage MAX script
Start Chaos Vantage
width50%
 Use the Start Chaos VantageInitiate Live Link to Chaos Vantage MAX script Scriptin 3ds Max. For convenience you can drag-n-drop it from ||Customize|| > Customize User Interface SketchUp. It can be accesses either from:
Fancy Bullets
typecircle
    • the Start Chaos Vantage button in the Chaos Vantage toolbar which is hidden by default but can be enabled from View > Toolbars > Chaos Vantage
    • the Start Chaos Vantage command accessible from Extensions > V-Ray > V-Ray Live Link
Using either of the two will initialize > Initiate Live Link  to Vantage in any toolbar for faster access. Click on the Initiate Live Link  to Vantage button and a live link session will be initialized between 3ds Max SketchUp and Chaos Vantage. The script   It will automatically:
Detect if you are using V-Ray 5 GPU as a renderer and ask if you would like to switch to it.
Fancy Bullets
typecircle
    • Start Chaos Vantage if it is not already running.;
    • Send the scene to Chaos Vantage on 20701 port  ;
    • When clicked again will close the Live Link connection.
width5%
width45%
Image Removed
GPU IPR
width50%
Start a GPU IPR Custom Live Link session in 3ds MaxSketchUp.
Expand
titleClick here to expand for manual IPR Live Link setup
In 3ds Max
width50%
1. Set V-Ray GPU 5 as renderer.
width5%
width45%
Sketchup
width50%
2. Enable Distributed rendering in the Perf. tab.
width5%
width45%
1. Open the Customize Live Link dialogue by going to Extensions > V-Ray > V-Ray Live Link > Customize Live Link:
1.1 Specify the following
width50%
3. Open the Render Servers dialogue:
3.1 Add a new server with the following settings:
Fancy Bullets
typecircle
  • Server  Address – add your local machine as as server. Enter either localhost or 127.0.0.1
  • Port range  – specify a port range for which Chaos Vantage awaits incoming data. By default it is 20701
31.2 Disable local host to reduce resource usage3.3 Close the Render Servers Customize Live Linkdialogue by clicking the OK button.
width5%
Image Removed
width45%
 section
In Chaos Vantage
width50%
1. Open Chaos Vantage.
width5%
width45%
width50%
2. Open the Live Link menu and make sure Start Server is enabled (greyed out). If Start Server on Application Start is enabled every time Chaos Vantage is launched  in stand-by mode and wait for incoming data.
width5%
width45%
width50%
3. Setup port range in Change Port.. menu and make sure the range entered here matches the one previously set in 3ds MaxSketchUp. Default is 20701.
width5%
width45%
Back In Sketchup
width50%
Start  Live link by going to Extensions > V-Ray > V-Ray Live Link > Start Custom Live Link.
width5%
width45%
width5%
width45%
width50%
Once a Live Link session is started the scene is transferred to Chaos Vantage, a thick blue contour line appears around the viewport and the status message in the lower right changes to [LIVE LINK]
UI Text Box
typeinfo
The Pause when app loses focus option in the Preferences menu will be ignored when in Live Link session.
To stop a Live Link session either click again on the Initiate Start Chaos Vantage button, Start Custom Live Link  to Vantage button option or open the VFB and stop the IPR.
width5%
width45%
Supported Features
The following changes made in 3ds Max SketchUp will be propagated through Live Link:
Fancy Bullets
typecircle
  • Editing, creating and deleting of:
    • Camera
    • Geometries
    • Lights
    • Materials
    • Textures
Known Limitations
The following require a restart of the Live Link Session in order to be updated properly.
Fancy Bullets
typecircle
  • Updating of:
    • V-Ray Proxy files (.vrmesh)
    • Environment
    • Light textures (e.g. rectangle light texture, dome light texture)
