This page provides information on the Live Link feature from SketchUp in Chaos Vantage.
The Live Link feature makes it possible to instantly see changes made in a SketchUp without the need to export and import .vrscenes in Chaos Vantage.
Live Link Setup
For Live Link to function properly please follow the steps below:
Installation
Live Link works only with officially released V-Ray 5 versions or stable nightly builds.
1. Download and install latest official V-Ray 5 for Sketchup build from the download button. Make sure you have appropriate licenses. If you experience problems please contact Chaos Support using the online form.
2. Download latest Chaos Vantage build from the download button. Make sure you have appropriate licenses. If you experience problems please contact Chaos Support using the online form.
After installation Live Link can be initiated by either of 2 ways:
Start Chaos Vantage
Use the Start Chaos VantageInitiate Live Link to Chaos Vantage Scriptin SketchUp. It can be accesses either from:
- the Start Chaos Vantage button in the Chaos Vantage toolbar which is hidden by default but can be enabled from View > Toolbars > Chaos Vantage
- the Start Chaos Vantage command accessible from Extensions > V-Ray > V-Ray Live Link
Using either of the two will initialize a live link session between SketchUp and Chaos Vantage. It will automatically:
- Start Chaos Vantage if it is not already running;
- Send the scene to Chaos Vantage on 20701 port ;
- When clicked again will close the Live Link connection.
Start Custom Live Link
Start a Custom Live Link session in SketchUp.
Once a Live Link session is started the scene is transferred to Chaos Vantage, a thick blue contour line appears around the viewport and the status message in the lower right changes to [LIVE LINK]
The Pause when app loses focus option in the Preferences menu will be ignored when in Live Link session.
To stop a Live Link session either click again on the Start Chaos Vantage button, Start Custom Live Link option or open the VFB and stop the IPR.
Supported Features
The following changes made in SketchUp will be propagated through Live Link:
- Editing, creating and deleting of:
- Camera
- Geometries
- Lights
- Materials
- Textures
Known Limitations
The following require a restart of the Live Link Session in order to be updated properly.
- Updating of:
- V-Ray Proxy files (.vrmesh)
- Environment
- Light textures (e.g. rectangle light texture, dome light texture)
