Utility Textures allow users to perform a variety of helpful functions on texture maps inside a scene (such as compositing textures together and value conversions), as well as provide color corrections option.
A Utility A Utility Texture can be replaced with another Utility Texture or any other type of V-Ray texture via the Replace With New Texture () button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.
width10%
width20%
Thumbnail
ThumbnailTitleTextBezier Curve
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VRHINO/Bezier+Curve+Correction
width10%
width20%
Thumbnail
ThumbnailTitleTextColor Correction
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VRHINO/Color+Correction
width10%
width20%
Thumbnail
ThumbnailTitleTextMix Map
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VRHINO/Mix+Map
width10%
width10%
width20%
Thumbnail
ThumbnailTitleTextMix Operator
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VRHINO/Mix+Operator
width10%
width20%
Thumbnail
ThumbnailTitleTextMix Value
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VRHINO/Mix+Value
width10%
width20%
Thumbnail
ThumbnailTitleTextMultiSub
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VRHINO/MultiSub
width10%
width10%
width20%
Thumbnail
ThumbnailTitleTextSimple Mix
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VRHINO/Simple+Mix
width10%
width20%
Thumbnail
ThumbnailTitleTextSpline Curve Correction
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VRHINO/Spline+Curve+Correction
width10%
width20%
Thumbnail
ThumbnailTitleTextTriPlanar
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VRHINO/TriPlanar
width10%
