This page provides details on the V-Ray for Revit UI and how it is integrated into the Revit interface.
The V-Ray for Revit Ribbon gives you provides access to all of the settings and options that you will need with are featured in V-Ray for Revit.
Section | |||||||||||||||
View
This allows you to select which one of the Provides a list of Revit 3D views to render.
Render
Allows you to choose your Provides Render type options and open up access to the V-Ray Frame Buffer.
Quality
Provides a drop down menu with a specific set of presets. They provide The preset settings ranging range from very low quality “Low” settings to “High+” settings.
Resolution
Allows you to choose your Provides Output and Crop Box resolution size modification options.
Lighting
Gives you Provides access to the options for the V-Ray Sun, V-Ray Dome Light, No V-Ray Lights, and Artificial Lights options.
Assets
Gives you Provides access to the V-Ray Asset Editor, V-Ray Appearance Manager, and Chaos Cosmos Browser.
Camera
Gives you Provides access to the V-Ray Camera settings.
Gives you Provides access to the the V-Ray Settings.
Opens Provides access to the online V-Ray for Revit Help documents.
Fancy Bullets | ||
V-Ray
Allows you Provides access to acquire your license and gives you access to the Online License Server.
