width62%
UV Noise On – Enables noise for the texture.
Animated UV Noise – Enables the noise to be animated.
UV Noise Amount – Specifies the amount of UV noise.
UV Noise Levels – Specifies the amount of noise iterations.
UV Noise Size –  Controls the scale of the noise.
UV Noise Phase – Controls the noise phase.
U Wave / V WaveSpecifies a sine wave offset in the U/V direction.
Noise AmountSpecifies the amount of noise to add to the texture.
Noise Frequency – Specifies the amount frequency.
Hue Noise Amount Introduces noise in the hue.
Hue Noise Frequency Specifies the noise frequency in the hue.
Saturation Noise Amount Specifies a noise amount for the saturation.
Saturation Noise Frequency Specifies what the noise frequency is in the saturation.
Value Noise Amount Specifies a noise amount for the value.
Value Noise Frequency Specifies what the noise frequency is in the value.
width5%
width33%
