This page provides information about the VRayRamp texture in Cinema 4D.
The VRayRamp texture is a gradient ramp texture that allows a texture to be attached to each point available in the gradient ramp.
UI Path: Texture > V-Ray > VRayRamp
Properties
Type – Specifies the type of ramp to create:
V – Creates the gradient along the V axis.
U – Creates the gradient along the U axis.
(U+V)/2 – Creates a diagonal gradient.
Radial – A gradient with a radial transition.
Circular
Box – A gradient with a box radial transition.
UV
Four Corner – A gradient that transitions linearly between colors assigned to each corner.
Tartan – Creates a gradient with a plaid pattern.
Gradient – Specifies the gradient colors.
Position 1/ Position 2 – Specifies the position of color in the gradient. A texture map can be used to specify the position.
Noise
UV Noise On – Enables noise for the texture.
Animated UV Noise – Enables the noise to be animated.
UV Noise Amount – Specifies the amount of UV noise.
UV Noise Levels – Specifies the amount of noise iterations.
UV Noise Size – Controls the scale of the noise.
UV Noise Phase – Controls the noise phase.
U Wave –
V Wave –
Noise Amount – Specifies the amount of noise to add to the texture.
Noise Frequency – Specifies the amount frequency.
Hue Noise Amount –
Hue Noise Frequency –
Saturation Noise Amount –
Saturation Noise Frequency –
Value Noise Amount –
Value Noise Frequency –
