  1. Go to V-Ray Renderer ROP > Options > Materials and enable Material Override option.
  2. Select the Material to use for overriding.
  3. In the Pattern Mode, select either Pattern or Selection.
  4. In Override For, select the objects that will have their materials overridden.
  5. Render. Now the selected material should be used for the selected objects.
  6. Enable the Use Displacement from Override Material option to override the displacement/subdivision settings for the selected objects. If the override material has a Displacement VOP inside, it is used. If such a VOP is not present, no displacement is applied to the selected Override For objects.
ui-
titleDownload Example File
urlhttps://drive.google.com/uc?export=download&id=1OWOHWKf0xVtJjqV_pdIqRqVaYyTfiYK8
ui-text-box
typenote
Instead of exporting and assigning the materials specified on the Geometry node or in the SOP network, the specified Material is used for the specified Override For objects.
Displacement is handled separately by using the Use Displacement from Override Material option - when enabled, the displacement under the override material is used, if present. If not present, no displacement is applied to the selected Override For objects. This allows the user to disable displacement for a specific set of objects.
