VrayVFBVRayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise – Specifies whether to denoise this render element.
Add background – When enabled, adds the background to the render element.
