width50%
The VRayMDLMtl material loads NVIDIA Material Definition Language files (.mdl) and renders them directly with V-Ray.
V-Ray supports NVIDIA Material Definition Language, version 1.4.4.
UI Text Box
typewarning
 The MDL Material does not work within Distributed Rendering at this time.
width5%
width45%
UI Expand
titleUI Path: ||Right-click on the geometry|| > Assign New Material...
width5%
width300px
||Right-click on the geometry|| > Assign New Material... > VRay section > VRay Mtl MDL
width5%
width280px
||V-Ray Shelf|| > Right-click to Create V-Ray Materials button > VRay Mtl MDL
width500px
||Hypershade|| > Window tab > Create... > VRay section > VRay Mtl MDL
width5%
width5%
Installed Material Library
4.  Find the folder where Substance Designer keeps its MDL modules (usually C:\Program Files\AllegorithmicAdobe\Adobe Substance 3D Designer 5\resources\view3d\iray\alg but may differ from version to version) and append its path to the same environment variable.
VRAY_MDL_PATH_MAYA2018_x64=C:\Program Files\Chaos Group\V-Ray\Maya 2018 for x64\mdl;C:\Program Files\AllegorithmicAdobe\Adobe Substance 3D Designer 5\resources\view3d\iray\alg;X:\MDL
Known Limitations
Fancy Bullets
typecircle
  • material_emission.mode is ignored
  • material.backface is ignored
  • df::diffuse_transmission_bsdf is not supported
  • df::backscattering_glossy_reflection_bsdf is not supported
  • df::measured_bsdf is not supported
  • From the “alternative distribution functions”, only df::microfacet_ggx_smith_bsdf is implemented
  • df::measured_edf and df::spot_edf are not supported
  • df::anisotropic_vdf is not supported
  • 3D textures are not yet supported
References
Fancy Bullets
typecircle
