width60%
The Environment section in V-Ray render parameters is where you can specify a color and a texture map to be used during GI and reflection/refraction calculations. If you don't specify a color/map then the background color and map specified in the 3ds Max Environment dialog will be used by default.
UI Path: ||Render Setup window|| > V-Ray tab > Environment rollout
width5%
width35%
