width50%
The VRayPlane implements a procedural infinite plane for V-Ray during rendertime. The source code of VRayPlane is also available as part of the V-Ray Geometry SDK.
It can be created from the the VRay category of the Create tab.
UI Expand
titleUI Path: ||Create menu|| > V-Ray > V-Ray Plane
width50%
Image RemovedImage Added
width1%
width49%
||Command panel|| > Create tab > Geometry > V-Ray category > VRayPlane button
||V-Ray Toolbar|| > V-Ray Plane buttonImage Removed
Image Added
||V-Ray menu|| > Create > Geometry > V-Ray Plane
width5%
width45%
The 3ds Max teapot sitting atop a VRayPlane.
