width60%
The VRayNoiseLevel Render Element shows the level of noise in the scene. It is the equivalent of the noiseLevel render element generated by the V-Ray Denoiser. VRayNoiseLevel is available as a separate render element for situations where it would be useful on its own outside of the V-Ray Denoiser, such as for manual denoising or debugging purposes.
In this render element, black areas indicate no noise, white pixels indicate a great deal of noise in that area, and grey pixels indicate a moderate level of noise.
UI Expand
titleUI Path: ||Render Setup window|| > Render Elements tab > Add button > VRayNoiseLevel
Image RemovedImage Added
width5%
width35%
width60%
VrayVFB – When enabled, the render element appears in the V-Ray Frame Buffer.
Deep output – Specifies whether to include this render element in deep images.
width5%
width35%
