This page describes the VRayNoiseLevel Render Element and its uses.
The VRayNoiseLevel Render Element shows the level of noise in the scene. It is the equivalent of the noiseLevel render element generated by the V-Ray Denoiser. VRayNoiseLevel is available as a separate render element for situations where it would be useful on its own outside of the V-Ray Denoiser, such as for manual denoising or debugging purposes.
In this render element, black areas indicate no noise, white pixels indicate a great deal of noise in that area, and grey pixels indicate a moderate level of noise.
VrayVFB – When enabled, the render element appears in the V-Ray Frame Buffer.
