This page provides information on the Phoenix Deadline Simulation window.
The Deadline Simulation window is used to submit Phoenix simulations to Deadline. This way Phoenix would not use a GUI license, see Simulation Without a GUI License.
UI Text Box
typetip
UI Path: ||Phoenix FD menu|| > Submit Simulation to Deadline...
The path to the Phoenix scripts must be provided within the following window. The path is set by default to the correct values, so it should be changed only if you need to provide your own scripts.
When a simulation is submitted to Deadline, the selected Phoenix simulators in the scene will be simulated in the order they were selected. If no simulators are selected in the scene, all simulators will be simulated.
width20%
width60%
width20%
Deadline Repository – Specifies location of the Repository, the global file system component used by Deadline.
Simulation Script Location – Specifies the location of the Phoenix simulation script. This path is set by default.
