width60%
Default color – The color that is returned if the specified user property cannot be found on the currently shaded object.
Default texmap – Specifies a default texture to be used if the user property cannot be found on the currently shaded object.
Attribute name – A string that specifies the name of the User-Defined property.
width5%
width35%
Image RemovedImage Added
Format of the User Properties
bordertrue
width25%
The material with VRayUserColor texture as Diffuse color, assigned to both objects.
width25%
Object properties for the first object
width25%
Object properties for the other object
width25%
Render of the two objects. Even though they use the same material, the diffuse color is read from their object properties.
