This page provides information on the OCIO Map.
width60%
VRayOCIO is a texture that allows users to apply OpenColorIO (OCIO) color transformations to textures in 3ds Max to manage their look.
In the example shown, an aces_0.1.1.ocio file is used to define the output colors of the texture.
UI Expand
titleUI Path: ||Material Editor|| > Material/Map Browser > Maps > V-Ray > VRayOCIO
width5%
width35%
width60%
Basemap – The base texture that will be corrected.
OCIO config – Manually specifies an OCIO configuration. If not specified, the OCIO environment variable is used.
Input output selection – Determines how the input and output color spaces are specified:
by color space – The user specifies the input and output color spaces directly.
by role – The user specifies the input and output color space depending on the task that they want to perform as defined in the OCIO configuration.
Mode – Specifies what color transformations to be performed:
ColorSpace – The texture performs color space conversions.
CDL – The texture performs an ASC CDL transformation. CDL stands for "Color Decision List" which is a color grading information exchange format developed by the ASC (American Society of Cinematographers).
FileTransform – The texture performs a color transformation based on another file (i.e. .3dl, .lut, .cube etc).
LogConvert – The texture performs log2lin or lin2log conversion.
Display – The texture performs color space conversion for display.
Look – The texture performs a look transform. The OCIO config must define looks for this mode to work.
Reload – Reloads the OCIO configuration.
width5%
width35%
Mode-Specific Parameters
Depending on the chosen mode, different parameters are available.
ColorSpace Parameters
width60%
These parameters are available when the Mode is set to ColorSpace.
In – Specifies the input color space (the color space that the input texture is in).
Out – Specifies the output color space (for rendering, this would typically be a linear color space).
From basemap file name – When enabled, the texture tries to determine the correct in/out color spaces based on the file name from the base texture (assuming it is a Bitmap or VRayBitmap texture).
width5%
width35%
CDLTransform Parameters
width60%
These parameters are available when the Mode is set to CDLTransform.
Slope rgb – Multipliers for the red/green/blue color components.
Offset rgb – Offset values for the red/green/blue color components.
Power rgb – Gamma values for the red/green/blue color components.
Saturation – The saturation value; 0.0 makes the image grayscale.
Use file – When enabled, the CDL parameters are read from a .cc or a .ccc file instead of specified directly.
File – Specifies a .cc or .ccc file to read.
Cccid – Color correction id as specified in the color correction file.
Direction – Specifies whether the forward or the inverse CDL transformation will be applied.
Save cc – Allows the CDL parameters to be saved in a .cc file.
get values from file – When Use file is enabled, this button copies the parameters from the file into the texture parameters so that they can be adjusted if needed.
width5%
width35%
FileTransform Parameters
width60%
These parameters are available when the Mode is set to FileTransform.
File – Specifies a color transformation file (.3dl.cube.lut etc).
Cccid – Color correction id if present in the file.
Direction – Specifies whether forward or inverse color transformation should be applied. Not all file formats support inverse transformations.
Interpolation – If the file contains tabulated LUT data (i.e. .cube files), specifies how this data is interpolated.
nearest – Nearest neighbor in all dimensions. This method is fast, but may introduce artifacts, especially in textures with smooth gradients.
linear – Linear interpolation in all dimensions . This is a smooth method, but is slower than nearest.
tetrahedral – Tetrahedral interpolation in all directions.
best – Chooses the best interpolation type for the requested context. Currently the same as linear.
width5%
width35%
LogConvert Parameters
width60%
These parameters are available when the Mode is set to LogConvert.
Operation – Specifies whether to convert from linear to log space or vice versa.
width5%
width35%
Display Parameters
width60%
These parameters are available when the Mode is set to Display.
In – Specifies the color space of the base texture.
Device – Specifies a viewing device from the devices listed in the OCIO configuration.
View transform – Specifies the desired view transformation.
width5%
width35%
Look Parameters
width60%
These parameters are available when the Mode is set to Look.
In – The color space of the base texture.
Look – The name of the look if the OCIO configuration defines looks.
Out – The output color space.
Direction – Specifies whether to apply forward or inverse transformation.
Ignore errors – When enabled, attempts to perform color corrections even if there are errors.
width5%
width35%
Context
See the OCIO library documentation for more information.
References
The official OpenColorIO web page: http://opencolorio.org/
