width60%
V-Ray Rectangle Light node component creates a rectangle light source. This light source can be connected to the V-Ray Render which will automatically add it to the rendered scene. If a list of input Planes is connected to this component, multiple lights are generated. Multiple Size values can also be used.
The Number of Instances tag at thebottom of the node component indicates how many times the object is currently being instanced.
The number of input Planes determines the lights count. The number of Size values do not affect the lights count.
width5%
width35%
Light (Generic Data)– Light output that can be connected to a V-Ray Render node component.
Example
width50%
width50%
Rectangle Light node Light component connection. Note the toggled off Simple Light Rig plugged used as an override. If there is no Light Rig input in the V-Ray Render component it will always internally create one.
