width50%
The Corona Proxy is Chaos Corona's own proxy solution, helpful in decreasing the number of polygons in the scene and thereby simplifying meshes for the viewport to keep scenes manageable and to bake objects with animation to keep playback at a reasonable frame rate.
width5%
width45%
ImageImage Added
Object
Properties
width50%
Proxy fileThis slot allows Allows the loading of a previously saved object as Corona Proxy. To load a proxy file, use the ellipsis ( ... ) button right next to the empty slot.
Keep in memory – When this option is enabled, and the visualization method is set to Full Mesh, the model is always loaded into RAM, and this control is ignored.
UI Text Box
typenote
Do not flush a model from RAM between renders. It increases scene parsing speed and memory consumption when enabled.
Pick from sceneThis option allows Allows the creation of a new proxy from an object picked from the current scene.
Duplicate to MeshThis option clones Clones the proxy to a regular mesh object.
Reload from diskThis option reloads Reloads a previously loaded proxy file from a disk.
Units – Use this parameter to set a specific measurement unit for the proxy object. Depending on the selected unit, the object's size will be affected.
UI Expand
titleClick here to see the available units.
Auto
Kilometers
Meters
Centimeters
Millimeters
Micrometers
Nanometers
Miles
Yards
Feet
Inches
Visualization method – These options set the viewport visualization method. Available visualization methods are:
Solid bounding box – Using this option
will display
displays the proxy object as a solid box.
Wire bounding box – Using this option
will display
displays the proxy object as a wire box.
Point cloud – Using this option
will display
displays the proxy object as a cloud made out of points.
UI Text Box
typetip
The Point Cloud visualization method is the recommended solution, as it makes it easy to see the shape of the proxy object while keeping great viewport performance.
Full mesh – Using this option
will display
displays the entire geometry that the proxy object contains as if it wasn't a proxy object.
UI Text Box
typenote
The Full Mesh option should not be used in cases involving complex geometry, as it does not bring any viewport performance improvement compared to displaying the original geometry.
Point cloud displayedThis parameter defines Defines the level of visibility for the Corona Proxy object in a viewport.
UI Text Box
typenote
The Point cloud displayed parameter will be is only available when the Visualization method is set to Point cloud.
width5%
width45%
ImageImage Added
Animation
width50%
Enable animation – When enabled and if there's animation data included in the proxy file, then the object's animation will start playing.
Mode – These options allow you to select the animation playback method.
Frame offsetThis parameter will offset Offsets the animation starting point for the Corona Proxy object.
Speed multiplier This value will speed Speeds up or slow slows down the animation playback for the Corona Proxy object.
UI Text Box
typeinfo
The animation options are only available if animation data is included in the proxy file.
width5%
width45%
Image Added
Examples
width1%
width48%
Image slider
Corona Proxy -
Panel
titleVisualization mode = Solid bounding box
Panel
titleVisualization mode = Point cloud
Panel
titleVisualization mode = Wire Bounding Box
Panel
titleVisualization mode = Full mesh
width2%
width48%
Image slider
Corona Proxy -
Panel
titlePoint cloud displayed = 1%
Panel
titlePoint cloud displayed = 10%
Panel
titlePoint cloud displayed = 25%
Panel
titlePoint cloud displayed = 50%
Panel
titlePoint cloud displayed = 75%
Panel
titlePoint cloud displayed = 100%
width1%
