This article explains the settings and values for the Corona Proxy object.
Floatingpagetoc
width50%
The Corona Proxy is Chaos Corona's own proxy solution, helpful in decreasing the number of polygons in the scene and thereby simplifying meshes for the viewport to keep scenes manageable and to bake objects with animation to keep playback at a reasonable frame rate.
width5%
width45%
