UI Expand
titleWorkflow for modifying an existing particle system
UI Steps
UI Step
width60%
Select Resimulation → Enable Particle Resimulation → Enable and select the respective particle system below (i.e. Splash and Mist, Foam or Wetting).
width40%
Image RemovedImage Added
UI Step
width60%
Modify the particle system's settings - e.g. for Foam, go to the Foam rollout and tweak the parameters there.
width40%
UI Step
width60%
Hit Start to run the simulation again - repeat this process until you are happy with the result.
width40%
UI Expand
titleWorkflow for adding a particle system that did not exist prior to resimulating
UI Steps
UI Step
width60%
width40%
UI Step
width60%
Make sure the particle system's simulation is Enabled, e.g. for Foam open the Foam rollout → select the Enable option.
width40%
UI Step
width60%
Hit Start to run the simulation again - the particle system will be added to the cache sequence.
width40%
UI Expand
titleWorkflow for deleting an existing particle system
UI Steps
UI Step
width60%
width40%
UI Step
width60%
Make sure the particle system's simulation is Disabled, e.g. for Foam open the Foam rollout → deselect the Enable option.
width40%
UI Step
width60%
Hit Start to run the simulation again - the particle system will be removed from the cache sequence.
width40%
width55%
Start Frame
  • From Simulation | rs_start_from_sim – When enabled, the Resimulation will run run from the first frame of the base simulation to the simulation End Frame or the Custom Stop Frame, depending on the options.
  • Custom | resim_startframe - Explicitly sets the Start Frame of the Resimulation. This can also be a negative number.
Stop Frame
  • From Simulation | rs_stop_from_sim – When enabled, the Resimulation will run from the base simulation Start Frame or the Custom Start Frame to the last frame of the base simulation.
  • Custom | resim_stopframe - Explicitly sets the End Frame of the Resimulation. This can also be a negative number.
Expand – Opens a floating dialog that contains the selected rollout and automatically folds the command panel rollout.
? – Opens up the help documents for the Liquid Resimulation.
width5%
width40%
width55%
Div
idResimulation_Parameters
Enable Particle Resimulation resim_resimulate_particles – Enables/disables the Particle Resimulation.
Splash and Mist | resim_splash – Specifies that the Splash and Mist will be resimulated.
UI Text Box
typenote
The Affect Liquid parameter on the Splash and Mist rollout will be ignored when resimulating Splash, because the liquid is already simulated and cannot be changed without a full simulation.
UI Text Box
typenote
Resimulating the Foam on Hit parameter on the Splash and Mist rollout requires Splash and Mist to be resimulated.
Foam | resim_foam – Specifies that the Foam will be resimulated.
Wetting | resim_wet – Specifies that the WetMap particles will be resimulated.
UI Text Box
typenote
The Sticky Effect setting for Wetting in the Liquid rollout will be ignored when resimulating wetting. This is because the liquid is already simulated and cannot be changed without a full simulation.
width5%
width40%
Image Removed
Image Added
Resimulation Cache
UI Text Box
typetip
During resimulation, Phoenix reads cache files from the Base Cache Files Path, performs resimulation operations, and then saves a new cache sequence in the Output and Render Path.
For more information on how to set up resimulation paths, see the Tips and Tricks page.
