width50%60%
The VRayUserColor texture can be used to read User-Defined object properties from the currently shaded node and convert them to a color value. This allows you to use the same shading network on several different objects in the scene, but to control various aspects of the material through User-Defined properties. In the example shown here, the Default color is set to green.
UI Expand
titleUI Path: ||Material Editor|| > Material/Map Browser > Maps > V-Ray > VRayUserColor
width5%
width45%35%
Image Modified
bordertrue
width25%
width50%
The material with VRayUserColor texture as Diffuse color, assigned to both objects.
width25%
bordertrue
width2%
width46%
Object properties for the first object
width4%
width46%25%
Object properties for the other object
width2%
bordertrue
width25%
width25%
Render of the two objects. Even though they use the same material, the diffuse color is read from their object properties.
width25%
Fancy Bullets
typecircle
  • When rendering with V-Ray GPU, VRayUserColor supports setting UV and color sets from proxies and regular geometry.
