This page provides information on the V-Ray Point Cloud Color Texturetexture.
width60%
The VRayPointCloudColor map can be used to adjust the color saturation as well as to gain finer control over the appearance of the Autodesk Point Cloud Material.
On the right, you can see an exemplary workflow where the VRayPointCloudColor map is linked to the Self-Illumination map slot of a VRayMtl.
UI Text Box
typenote
Autodesk Point Cloud Material is not included in 3dsMax 2018.
UI Expand
titleUI Path: ||Material Editor|| > Material/Map Browser > Maps > V-Ray > VRayPointCloudColor
width5%
width35%
