width60%
The Sampler Info Render Element is a color image that provides information about the scene, with the choice to show any of various aspects as color blocks. This render element provides information about various aspects of the shaded points such as position, normal, bump normal, reflection/refraction vectors and UVW coordinates. This render element can be used either for world position passes or normal passes. It extracts particular information about the scene, converting the gathered information into RGB data for use in compositing.
UI Expand
titleUI Path: ||Render Setup window|| > Render Elements tab > Add button > VRaySamplerInfo
Image Modified
width5%
width35%
Image RemovedImage Added
width60%
VRayVFB – Enables the render element inside the V-Ray Frame Buffer.
Deep output – Specifies whether to include this render element in deep images.
Type  Controls the type of render element produced by VRaySamplerInfo:
Point  The X, Y, and Z coordinates of the point are converted to RGB data according to the Coord system that is set. This outputs a Position Pass for use in compositing.
Normal vector – The direction of the normal at the particular shaded point according to which Coord system is set.
Reflection vector  Commonly used for adjusting reflections in the composite.
Refraction vector – Commonly used for adjusting refractions in the composite.
UVW coordinates – Extracts the UVW coordinates of the object at the particular shaded point.  This can be used to apply another texture at a composite level.
Normal vector with bump mapping  Produces the bump normal according to the Coord system that is set.
Backward occlusion  The red and green components of this render element represent the screen position of the shaded point at the beginning of the motion-blurred frame, while the blue component represents camera occlusion at the beginning of the motion-blurred frame. Together with the Forward occlusion render element, this can be used for denoising and/or post-process motion blur.
Forward occlusion  The red and green components of this render element represent the screen position of the shaded point at the end of the motion-blurred frame, while the blue component represents camera occlusion at the end of the motion-blurred frame. Together with the Backward occlusion render element, this can be used for denoising and/or post-process motion blur.
Integer ID from node user attribute  Extracts any integer node user property into an integer render element. Can be used as an extended Object ID.
Float number from node user attribute – Extracts any floating-point node user property into a single-channel floating-point render element. Can be used to extract additional masks.
Tangent vector in object space –  Displays tangent vector according to the Object space.
Bitangent vector in object space – Displays bitangent vector according to the Object space.
Point multiplier  Acts as a multiplier when Type is set to Point.
Refract IOR  Sets the index of refraction when Refraction vector is set as the Type.
UVW channel – The UVW mapping channel used when the Type is set to UVW coordinates.
UVW mode  Specifies what happens to UVW values outside the 0.0-1.0 range of the unit texture square:
Normal  Stores the UVW coordinates without modification.
Clamp  UVW coordinates above 1.0 are clamped to 1.0, and values below 0.0 are clamped to 0.0.
Tile  Wraps the UVW coordinates to the unit texture square.
  Coord system – Controls the coordinate system used:
World – X, Y, and Z coordinates (in world space) of the point are converted to RGB data.
Object  X, Y, and Z coordinates (in object space) of the point are converted to RGB data.
Camera  X, Y, and Z coordinates (in camera space) of the point are converted to RGB data.
Relative  X, Y, and Z coordinates in the object space of the Relative node are converted to RGB data.
Relative node  When Coord system is set to Relative, this specifies the scene node relative to which the point/vector data is stored.
Output – Controls the way data is stored in the render element when the type is a normal vector, or a reflection/refraction direction:
Vector (signed)  Values are stored directly without modification, including negative components.
Color (unsigned)  Values are scaled down by 0.5 and offset by 0.5 so that (0, 0, 0) maps to (0.5, 0.5, 0.5), (-1, -1, -1) maps to (0, 0, 0) and (1,1,1) maps to (1,1,1). This avoids negative values which might be necessary for some compositing packages.
User attribute  Determines which user attribute to connect to when Integer ID from node user attribute or Float number from node user attribute are selected as Тype.
Occlusion bias  Controls the positional bias of the Backward occlusion & Forward occlusion types in order to prevent incorrect self-occlusion.
width5%
width35%
Image Removed
Image Added
Common Uses
The VRaySamplerInfoTex texture extracts particular information about the scene. It then converts the gathered information into RGB data that can be used for compositing. Here are examples of the types of data that can be extracted, and how that data is displayed in the render element.
The following examples have the coordinate system set to world space.
width10%30%
Image Removed
with type set to Normal vector
width40%
Image Removed
with type set to Point (world space)
width40%
width10%
width10%
width40%
Image Removed
with type set to Reflection vector (world space)
width40%
Image Removed
with type set to Refraction vector (world space)
width10%
width10%
width40%
Image Removed
with type set to UVW coordinates
width40%
Image Removed
Sampler Info Render Element with type set to
width10%
Image slider
Panel
borderStylenone
Image Added
Point Type in world space
Panel
borderStylenone
Image Added
Normal Type in world space
Panel
borderStylenone
Image Added
Reflection vector Type in world space
Panel
borderStylenone
Image Added
Refraction vector Type in world space
width30%
The following examples have the coordinate system set to object space.
width10%30%
Image Removed
Reflection vector (object space)
width40%
Image Removed
with type set to Point (object space)
width40%
width10%
Image slider
Panel
borderStylenone
Image Added
Point Type in object space
Panel
borderStylenone
Image Added
Reflection vector Type in object space
Panel
borderStylenone
Image Added
Refraction vector Type in object space
width30%
width10%
Image Removed
Refraction vector (object space)
10%
width80%
width
The following examples have the coordinates system set to camera space.
width10%30%
width40%
Image Removed
Sampler Info Render Element with type set to Point (camera space)
width40%
Image Removed
Sampler Info Render Element with type set to Reflection vector (camera space)
width10%
Image slider
Panel
borderStylenone
Image Added
Point Type in camera space
Panel
borderStylenone
Image Added
Reflection vector in camera space
Panel
borderStylenone
Image Added
Refraction vector in camera space
width30%
width10%
width40%
Image Removed
Sampler Info Render Element with type set to Refraction vector (camera space)
width40%
Image Removed Sampler Info Render Element with type set to Refraction vector (relative space)
10%
width
The following examples have the coordinates system set to relative space.
width10%30%
width40%
Image Removed
Sampler Info Render Element with type set to Point (relative space)
width40%
Image Removed
Sampler Info Render Element with type set to Reflection vector (relative space)
Image slider
Panel
borderStylenone
Image Added
Point Type in relative space
Panel
borderStylenone
Image Added
Reflection vector Type in relative space
Panel
borderStylenone
Image Added
Refraction vector Type in relative space
10%
width30%
width
Example: Re-texturing in composite
Using the VRaySamplerInfo Render Element, makes it is possible to apply a new texture to an already rendered still or sequence via setting its Type to UVW coordinates. This then enables the creation of what effectively amounts to a new Diffuse Filter Render Element which can then be used in a composite, enabling a change of texture to be easily made. It is worth noting that any UV stretching on the model will carry carries through into the UVW pass created by VRaySamplerInfo as can be seen in the examples below.
width10%
width40%
Image Removed
The Sampler Info with type set to UVW coordinates (uvw mode = normal)
width40%
Image Removed
Beauty render prior to re-texturing in composite
width10%
width10%
width40%
Image Removed
New texture image applied in composite.
(This effectively creates a new Diffuse Filter Pass)
width40%
Image Removed
Re-textured Beauty render (done purely at a composite level)
width10%
the VRaySamplerInfo. See the render before and after compositing.
Before after
darktrue
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Anchor
uvwTypes
uvwTypes
Supported UVW Coordinate Types
Pass TypeCoord. SystemUVW ModeOutputV-Ray RenderV-Ray GPU
PointWorld  (tick)(tick)
PointObject  (tick)(error)
PointCamera  (tick)(tick)
PointRelative  (tick)(error)
NormalWorld Vector (signed) or Color (unsigned)(tick)PARTIAL
NormalObject Vector (signed) or Color (unsigned)(tick)(error)
NormalCamera Vector (signed) or Color (unsigned)(tick)PARTIAL
NormalRelative Vector (signed) or Color (unsigned)(tick)PARTIAL
ReflectionWorld Vector (signed) or Color (unsigned)(tick)(error)
ReflectionObject Vector (signed) or Color (unsigned)(tick)(error)
ReflectionCamera Vector (signed) or Color (unsigned)(tick)(error)
ReflectionRelative Vector (signed) or Color (unsigned)(tick)(error)
RefractionWorld Vector (signed) or Color (unsigned)(tick)(error)
RefractionObject Vector (signed) or Color (unsigned)(tick)(error)
RefractionCamera Vector (signed) or Color (unsigned)(tick)(error)
RefractionRelative Vector (signed) or Color (unsigned)(tick)(error)
UVW coordinates Normal (tick)(tick)
UVW coordinates Clamp (tick)(tick)
UVW coordinates Tile (tick)(error)
Normal vector with bump mappingWorld Vector (signed) or Color (unsigned)(tick)(error)
Normal vector with bump mappingObject Vector (signed) or Color (unsigned)(tick)(error)
Normal vector with bump mappingCamera Vector (signed) or Color (unsigned)(tick)(error)
Normal vector with bump mappingRelative Vector (signed) or Color (unsigned)(tick)(error)
Backwards occlusion   (tick)(error)
Forward occlusion   (tick)(error)
Integer ID from node user attribute   (tick)(tick)
Float number from node user attribute   (tick)(tick)
