This example demonstrates the effect of the sun direction. The Sun is positioned such as its rays hit the ground at certain degrees. Note how in addition to the scene brightness, the sun position also changes the appearance of the sky and the sun light color.
Section | ||||||||||||||||||||||||||||||||||||||||||
Sun Parameters
Enabled: on, Turbidity: 3.0, Intensity multiplier: 0.01
Sky Parameters
Enabled: on, Intensity multiplier: 0.01, Size multiplier: 1.0
Anchor | ||||
Options
Enabled: on, Turbidity: 2.0, Intensity multiplier: 1.0, Size multiplier: 1.0. Notice how the shadows move towards the center of the render, that is towards the shadow casting object when the value is higher.
Example: VRay Sun and Sky with Different Color Mapping Types
Enabled: on, Height Z: 800, Turbidity: 3.0, Intensity multiplier: 0.01, Size multiplier: 1.0
Clouds
Anchor | ||||
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Anchor | ||||
Anchor |
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Anchor | ||||
Example: Contrails Time
The frames in this animation show the Contrails time parameter with values ranging between 0 and 2.0, with a step of 0.2.
Fancy Bullets | ||||||
References and links
Anchor | ||||
Anchor | ||||
An online version can be found at http://www.cs.utah.edu/~shirley/papers/sunsky/ (Please note that this link is no longer valid)
This paper includes source code examples and is the base for the VRaySun and VRaySky pluginsthe VRaySun and VRaySky plugins.
[2] R. H. B. Exell, The intensity of solar radiation, 2000
This page is available at http://www.jgsee.kmutt.ac.th/exell/IntensitySolarRad.pdf (Please note that this link is no longer valid).
This document contains information about the average intensity of the solar radiation, as well as some specific measurements.
[5] Hosek L, et al, An Analytic Model for Full Spectral Sky-Dome Radiance
This document can be found online at
http://cgg.mff.cuni.cz/projects/SkylightModelling/HosekWilkie_SkylightModel_SIGGRAPH2012_Preprint_lowres.pdf
Describes the Hosek sky model used by the VRaySun and VRaySky
