width60%
The Raw Total Lighting Render Element is the sum of all raw lighting (both direct and indirect) in the scene, without any diffuse details. This render element is useful for changing the appearance of the scene's lighting in a compositing or image editing application.
UI Expand
titleUI Path: ||Render Setup window|| > Render Elements tab > Add button > VRayRawTotalLighting
width5%
width35%
Image RemovedImage Added
width60%
VrayVFB  – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Deep output – Specifies whether to include this render element in deep images.
Color mapping – Applies the color mapping options specified in the  Color mapping  rollout (Render Setup window > V-Ray tab) to this render element. This option is enabled by default.
Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier.
Denoise –  Specifies whether to denoise this render element.
width5%
width35%
Common Uses
The Raw Total Lighting Render Element is useful for changing the appearance of the entire lighting of the scene, after rendering, using a compositing or image editing application. Below are a couple of examples of possible uses. The first two images show the render element itself and the Beauty render put together. In the following examples, a Matte Render Element was used to isolate different parts of the scene, and then the A Cryptomatte Render Element is used to isolate the floor, the windows along with the curtains and the stone fence, and the ceiling. Then the Raw Total Lighting Render Element was brightened is brightened and tinted differently for each element to show the range of editing possible.
width10%
width40%
Image Removed
width40%
Image Removed
The Original Beauty Composite
width10%
width10%
width40%
Image Removed
Brightened Lights with different brightening for the floor, wall, and ceiling
width40%
Image Removed
Tinted Lights with different tinting for the floor, wall, and ceiling
width10%
possibilities. See the render before and after compositing.
Before after
darktrue
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Underlying Compositing Equation
VRayRawTotalLighting x VRayDiffuseFilter = VRayTotalLighting
Image Added
Image Removed
VRayRawLighting + VRayRawGlobalIllumination = VRayRawTotalLighting
