Common Uses
The The Material Select Render Element is is useful for isolating geometry in a scene based on the selected material. In the examples shownexample, the window frame material was selected.
material applied to the sofa is selected using this method, and it is then color corrected. See how the render looks before and after compositing.
Before after | |||||||||||||||||||||||||
Section | |||||||||||||||||||||||||
