CSS Stylesheet |
.wiki-content .confluence-embedded-file-wrapper.confluence-embedded-manual-size { vertical-align: text-bottom; } |
This page provides information about the Camera tab functionalities in Chaos Vantage.
The Camera tab allows control over the camera. It has five pop-up windows - Resolution, Sensor and Lens, ExposureThe tab has advanced settings for resolution, sensor and lens, exposure, Depth of Field, tilt and Tilt and Shift, shift, and camera clipping that offer finer control.
UI Text Box | ||
There is limit of 1000 cameras - regardless whether they are imported or created inside Chaos Vantage. |
UI Text Box | ||
You can use the right mouse button click to reset the parameters numeric values to defaults. |
Section | ||||||||||||||||||||||||||||||||
Advance parameters
Resolution
Sensor & Lens
Exposure
Motion Blur
Depth of Field
Tilt & Shift
Clipping
