width45%
Corona Renderer includes its own Virtual Frame Buffer (VFB) window and interface that has been tuned to the most common needs of artists and can provide a very decent post-production experience and results.
width5%
width55%
Corona VFB (Virtual Frame Buffer)
Corona VFB
Buttons
ButtonDescription
Saves currently displayed element in different file types.
Press and hold "Save" button:
Save allSaves each render element as a separate file using a specified format.
Save CXR Stores all the information from the VFB (all render passes, including the LightMix, tone mapping, denoising data, etc...) inside a single CXR file.
Copies the content of the Corona VFB to the native 3ds Max VFB.
Copies the currently displayed element to the clipboard.
Useful for pasting the content of the VFB into other apps without the need to save the file.
Refreshes VFB.
Forces a VFB refresh. Useful mostly when using very high VFB refresh intervals.
Clears the VFB.
Toggles visibility of the side panel.
Selects a region to be rendered.
Left-click and hold to draw a region. Drag region border with Control key to use "fuzzy regions".
Allows to pick object from VFB.
Left-click to select an object. Right-click to select and object or set camera focus to the selected point in scene. Works also in interactive rendering.
Selects the element to be displayed.
Zooms in.
Zooms out.
Resets zoom.
Stops render.
Press and hold "Render" button:
Render – Starts render.
Start IR Starts Interactive Render.
Resume last resumes last render.
Resume file – allows to continiue previously saved render in Corona EXR format.
