width55%
The V-Ray Car Paint material simulates a metallic car paint. It is a complex material with four layers: a base diffuse layer, a base glossy layer, metallic flakes layer, and clear coat layer. The material allows the adjustment of each of these layers separately.
UI Path: ||mat Network|| > V-Ray > Material > V-Ray Car Paint
Image Removed
width5%
width40%
