width50%
The
VRayMDLMtl
material
loads
NVIDIA
Material
Definition
Language
files
(.mdl)
and
renders
them
directly
with
V-Ray.
V-Ray supports NVIDIA Material Definition Language, version 1.5.2.
UI Text Box
typewarning
The MDL Material does not work within Distributed Rendering at this time.
The MDL Material is currently not supported by V-Ray for Maya 2024, running on macOS.
width5%
width45%
UI Expand
titleUI Path: ||Right-click on the geometry|| > Assign New Material...
width5%
width300px
||Right-click on the geometry|| > Assign New Material... > VRay section > VRay Mtl MDL
width5%
width280px
||V-Ray Shelf|| > Right-click to Create V-Ray Materials button > VRay Mtl MDL
width500px
||Hypershade|| > Window tab > Create... > VRay section > VRay Mtl MDL
width5%
width5%
