The V-Ray AOV ExtraTex (USD) node is used to export a V-Ray Extra Texture element based on the attached input. The input texture is applied over the geometry associated with the material holding the AOV bind.
UI Text Box | |||||
To create a global Extra Texture AOV, add a V-Ray ExtraTexAOV VOP in a shading network inside a Material Library VOP, and point a RenderVar LOP to the Extra Bind Name parameter value of the VOP node.
UI Path: ||mat Network|| > V-Ray > Texture: Utility > V-Ray AOV ExtraTex (USD)
