width60%
Stores an image of the light scattered by atmospheric or volumetric media such as Fog or Aerial Perspective.
width5%
width35%
Before after
afterLabelBeauty
beforeLabelAtmosphere
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Image Removed
UI Paths
||V-Ray Asset Editor|| > Render Elements (right-click) > Atmosphere
||V-Ray Asset Editor|| > Create Asset (left-click) > Render ElementsAtmosphere
width60%
Denoise – Specifies whether to denoise this render element.
width5%
width35%
Common Uses
width60%
The Atmosphere Render Element is useful for changing the appearance of the atmosphere and volumetric effects in a rendered image using compositing or image editing software. In the example, fog is generated using the Environment Fog. A warmer color is assigned to the fog and the intensity is increased using the Atmosphere RE.
width5%
width35%
Before after
darktrue
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Compositing
width10%
width80%
The Atmosphere Render Element is Added to the Beauty render to form the final image.
Image Modified
width10%
