UI Text Box | ||
UI Path: ||Select Fire Smoke Simulator | FireSmokeSim object|| > Modify panel > Interaction rollout |
Section | ||||||||||||||||||||||||||||
Anchor | ||||
Example: Geom Border Voxels
UI Text Box | ||
The example below shows the difference in emission when the object uses Inscribed (voxels intersecting the surface are non-solid therefore do not emit) vs Circumscribed (voxels intersecting the surface are solid) voxelization. |
