UI Text Box
typetip
UI Path: ||Select PhoenixFDSim|| > Attribute Editor > Rendering rollout > Volumetric rollout
Image Removed
width40%
Heat Haze | rendHeatHaze – Traces the ray changing direction according to the gradient of the Surface channel. A value of 1 corresponds approximately to the normal heat haze in the air caused by the temperature. If smoke or another channel is selected as the source, a larger value might be necessary to achieve a visible result. A value of 0 produces no heat haze. This parameter is available only when Mode is set to Volumetric Heat HazeSee the Heat Haze example below.
width60%
Image Added
Anchor
heatHaze
heatHaze
Example: Heat Haze
bordertrue
width10%
width40%
Heat haze: 0
width40%
Heat haze: 1
width10%
Render Elements
Volumetric Material ID | materialID – Material ID color for the MateralID Render Element  when rendering in any of the Volumetric Render Modes. When rendering in Isosurface or Mesh Render Mode, this will be taken from the assigned material.
