Section | |||||||||||||||||||||
Example: Geom Border Voxels
UI Text Box | ||
The example below shows the difference in emission when the object uses Inscribed (voxels intersecting the surface are non-solid therefore do not emit) vs Circumscribed (voxels intersecting the surface are solid) voxelization. |
width | 10% |
Column | ||
Column | ||
width | 10% |
