UI Text Box | ||
To use Multiloaders, you need to have Corona Renderer 6 or newer installed in your system. You can use Multiloaders only to launch 3ds Max with Corona Renderer 5 or newer. You should be familiar with setting up Windows environment variables. You should be familiar with creating and running simple batch scripts. |
