« Previous Version 3 Next »
This page provides information on a feature called Multiloaders, which you can use to launch 3ds Max with a specific version of Corona, or even multiple instances of 3ds Max at the same time with different Corona versions each. While this is not a common scenario, it may be sometimes useful, for example when setting up render farms, using specific 3ds Max versions with specific Corona versions, or investigating problematic scenes using multiple Corona versions without the need to reinstall Corona multiple times.
Sometimes you may want to:
  • Easily switch between different versions of Corona without the need to manually copy the plugin files into the appropriate 3ds Max installation directories or re-installing Corona
  • Run two or more instances of the same 3ds Max version at the same time, each with a different Corona version
Currently, it is not possible to have two or more versions of Corona installed on the same computer for the same 3ds Max version when using our universal installer. But there is a way to overcome this limitation using Multiloaders.
The method explained in this guide does not let you launch 3ds Max once and then select different versions of Corona from the render engines dropdown inside a single 3ds Max instance.
Requirements
To use Multiloaders, you need to have Corona Renderer 6 or newer installed in your system.
You can use Multiloaders only to launch 3ds Max with Corona Renderer 5 or newer.
You should be familiar with creating and running simple batch scripts
Introduction
Starting with Corona Renderer 6, the files CoronaMax20XX.dlr and CoronaMaxUtils20XX.dlt installed by our universal installer into the 3ds Max Plugins folder are not actually Corona Renderer plugins. These files only act as "dispatchers", loading the actual plugin files from another directory.
The actual plugin files are installed into %programfiles%\Corona when using the standard installation method, for example:
C:\Program Files\Corona\Corona Renderer for 3ds Max\2021\Corona_Release.dll
You can use the instructions in this guide to override this default path to a user-specified one. This way, you can decide which specific files to load when starting 3ds Max (e.g. Corona Renderer 6 plugin files or Corona Renderer 7 plugin files).
Instructions
Step 1: Install Corona
Download and install the newest version of Corona using the standard installation method in our universal installer. If, for any reason, you wish to install an older version, it has to be at least Corona Renderer 6 (the oldest supported version is 31.01.2020 daily build).
Step 2: Download and unpack the other Corona version(s) you would like to use
Download the additional versions of Corona you would like to use. They can be stable versions or daily builds. The oldest supported version is Corona Renderer 5.
Use the "Unpack files" option in the installers of each of the additional Corona versions you would like to use. Unpack the plugin files into any desired folders.
See: How to install Corona Renderer manually using the "unpack files" option?
Step 3: Set up the environment variable
Note: you can either manually add an environment variable in Windows (type "Edit the system environment variables" in the Start Menu search) or you can use a batch script (example below) to automate this for you.
The name of the variable is:
CORONA_3DSMAX_<YEAR>_LOAD_PATH
Set the variable to the sub-directory where CoronaMax_Release-<YEAR>.dll file is located after the unpacking.
For example, for Corona Renderer for 3ds Max 2019 and "C:\Corona Renderer" as your unpacking directory, set:
CORONA_3DSMAX_2019_LOAD_PATH
to
C:\Corona Renderer\Corona\Corona Renderer for 3ds Max\2019
The environment variable tells the "dispatchers" which of the actual Corona plugins to load.
Here is an example Batch command which does that and starts 3ds Max:
SET "CORONA_3DSMAX_2019_LOAD_PATH=C:\Corona Renderer\Corona\Corona Renderer for 3ds Max\2019" & START "" "%ProgramFiles%\Autodesk\3ds Max 2019\3dsmax.exe"
The environment variable method set by a Batch command only works for the current session. This means that:
  • It cannot be used to change the Corona version used in the currently running 3ds Max.
  • It allows you to have multiple sessions of the same or different 3ds Max versions running with the same or different Corona versions at the same time.
  • If you start 3ds Max normally (e.g. using the desktop shortcut), the currently installed version of Corona is used (the one installed using the universal installer).
  • It is safe to change the environment variable while 3ds Max is running.
It is also possible to set the environment variable permanently using the options available in Windows: open the Start Menu and type "environment", then select "Edit the system environment variables"
To revert to the version which is currently installed using the universal installer, unset the custom environment variable (if it was set permanently), or just launch 3ds Max normally (if it was set for the current session only).
Additional Considerations
When using different versions of 3ds Max and Corona, keep in mind that:
  • Opening scene files saved with a newer version of Corona using an older version of Corona is not supported and the file either does not open at all, or opens with various issues (such as some features not working, incorrect parameter values, etc).
  • It is not possible to open scene files saved with a newer version of 3ds Max using an older version of 3ds Max. The solution is to re-save the scene in an older 3ds Max format using the 3ds Max File > Save as dialog.
  • Opening scene files saved with an older version of Corona using a newer version of Corona is fine. We sometimes enable legacy switches to keep rendering the same between different Corona versions, so if you would like to try new features, you may need to enable them manually in the newer version.
Using Multiloaders with Chaos Scatter
 To load a specific version of Chaos Scatter you can use the same steps as for Corona, but you need to use a different variable, since technically Chaos Scatter is a separate plugin:
CHAOSSCATTER_3DSMAX_<YEAR>_LOAD_PATH
For example:
CHAOSSCATTER_3DSMAX_2021_LOAD_PATH
Corona Renderer 6 and older, Converter Script, and Proxy Exporter
If you wish to install Corona Renderer 7 or newer and launch Corona Renderer 6 or older using the methods described in this article, you can encounter issues with the Corona Converter and Corona Proxy Exporter scripts. This is because the installation path for these scripts is changed. To solve this issue and be able to use the scripts, you need to manually copy the Corona Converter and Corona Proxy Exporter scripts from the directories where they are unpacked:
C:/Program Files/Autodesk/3ds Max <version>/scripts/CoronaRenderer/
Manually moving the scripts is not necessary when:
  • Running different versions of Corona Renderer 7 using the environment variable method (e.g. the final release and a daily build).
  • Having Corona Renderer 6 installed using the usual way (through the universal installer) and running Corona Renderer 7 using the environment variable method.
  • Having Corona Renderer 7 or newer installed using the usual way and using the environment variable method to run a different version of Corona Renderer 7 or newer.
Another solution is simply locating the currently needed Corona Converter and Corona Proxy Exporter scripts and manually launching them in 3ds Max, however this is bound to cause some issues such as the Corona Converter button in the Corona Toolbar not working.
