To add V-Ray Physical Camera parameters to a standard Houdini camera, use the Physical Camera button on the V-Ray Shelf. This will add a new tab to the selected Camera's parameters.
UI Path:
||Select camera|| > V-Ray Shelf > Physical Camera button
||Select camera|| > V-Ray menu > Object Properties > Physical Camera
width | 5% |
Column | ||
width | 5% |
Section | |||||||||||||||
