This page provides information on the V-Ray MtlVRayMesh
Page Contents
Table of Contents | ||
The V-Ray Proxy Material is used to assign shaders to the V-Ray Proxy geometry.
UI Paths
Section | |||||||||||||||
Node
The V-Ray V-Ray MtlVRayMesh node provides inputs for connecting shaders to a V-Ray Proxy.
VRayProxy SOP – Use this parameter to point to the V-Ray Proxy in the scene. Once it is selected, the V-Ray MtlVRayMesh node will create inputs for every shape or object in the proxy. Shaders can then be connected to them.
