MAXROOT | Specifies the root 3ds Max folder. |
PLUGINS | Specifies the plugins folder for 3ds Max; the default places it as a sub-folder of the 3ds Max root one. |
OPEN_README | Specifies whether or not to open the Read Me once the installation is complete. 1 opens the Read Me file. 0 does not open the Read me file. |
OPEN_CHANGELOG | Specifies whether or not to open the Change Log once the installation is complete 1 opens the Change Log. 0 does not open the Change Log. |
INSTALL_WIBU | Specifies whether or not the WIBU-KEY drivers will be installed. 1 starts the WIBU-KEY drivers installation. 0 skips the WIBU-KEY drivers installation. |
REG_LIC_SERVER | Specifies whether or not to register the Phoenix License Service. 1 registers the Phoenix License Service. 0 does not register the Phoenix License Service. This variable is only valid when the installation is set to either Workstation or License server |
REMOTE_LICENSE | Specifies whether the Phoenix license server runs locally or on another machine. 0 - the license server runs locally on the same machine. 1 - the server is on a different machine in the network. If this variable is 1, the license server itself will not be installed. To configure the license server settings, you will need to run the "setvrlservice" program after the installation. Normally it is located in "C:\Program Files\Chaos Group\Phoenix FD\3dsmax xxx for x64\setvrlservice.exe". The license server is specified using "-server" option, for example: "C:\Program Files\Chaos Group\Phoenix FD\3dsmax xxxx for x64\setvrlservice.exe" -server=10.10.10.11 Set the VRAY_AUTH_CLIENT_FILE_PATH environment variable to point to the folder that contains the vrlclient.xml file with the Phoenix FD license server settings (IP address and port number). |
STD_ROOT | Specifies the destination folder for Phoenix additional files (documents, SDK, and uninstall information). |
RTROOT | Specifies the destination folder for V-Ray RT files. This is only available in the V-Ray version of Phoenix. |
SHOULDUNINSTALL | Specifies whether or not the installation will uninstall previous version: 1 uninstalls previous version; 0 skips the uninstallation of previous version. |
