Type – – Specifies the color space for the loaded image file.The value is automatically selected when loading a new file by looking for the strings "_lin_srgb", "_srgb" and "_raw" in the file name. It also considers the file extension. You can manually modify the value.
UI Text Box
type
info
High dynamic range images (hdr, exr) will load with Inverse gamma type, unless "_srgb" is found in the name string - then sRGB Type will be automatically set instead. All other file types (8-bit images like jpg, png, and other files) will automatically load with types according to the string found in their file names: sRGB for "_srgb", None for "_lin_srgb" and From 3ds Max if no such string is found. Additionally, all files with any extension that have "_raw" string in their name load with Type None. This way the most appropriate type respective to the loaded file is applied.
None – No correction is applied; Inverse gamma – The color space is controlled through the Inverse Gamma parameter. sRGB – The loaded image is considered in sRGB color space; From 3ds Max – The gamma is controlled from 3ds Max gamma settings (Customize -> Preferences -> Gamma and LUT). Auto – Automatically determines the color transfer function. If a bitmap file name contains the string "_srgb" the transfer function is sRGB. If a bitmap file name contains the strings "_lin_srgb" or "raw", no correction is applied. For bitmap files with 8 bits per color component and 3 or 4 color components (like png, jpg and other), the transfer function is sRGB. In all other cases, no correction is appliedNone – No correction is applied; Inverse gamma – The color space is controlled through the Inverse Gamma parameter. sRGB – The loaded image is considered in sRGB color space; From 3ds Max – The gamma is controlled from 3ds Max gamma settings (Customize -> Preferences -> Gamma and LUT).
Inverse gamma – A gamma–correction value for the image. For example, if the bitmap was saved to disk with a 2.2 gamma correction, you need to enter 0.4545 to remove that correction for the rendering.
width
5%
width
35%
Image Modified
Viewport
width
60%
Use full resolution for viewport – When enabled, ignores the requested viewport resolution and uses the bitmap resolution instead. This allows high-quality previews for specific maps regardless of the Max viewport settings.
