Basemap – The base texture that will be corrected.
OCIO config – Manually specifies an OCIO configuration. If not specified, the OCIO environment variable is used.
Input output selection – Determines how the input and output color spaces are specified:
by color space – The user specifies the input and output color spaces directly. by role – The user specifies the input and output color space depending on the task that they want to perform as defined in the OCIO configuration.
Mode – Specifies what color transformations to be performed:
ColorSpace – The texture performs color space conversions. CDL – The texture performs an ASC CDL transformation. CDL stands for "Color Decision List" which is a color grading information exchange format developed by the ASC (American Society of Cinematographers). FileTransform – The texture performs a color transformation based on another file (i.e. .3dl, .lut, .cube etc). LogConvert – The texture performs log2lin or lin2log conversion. Display – The texture performs color space conversion for display. Look – The texture performs a look transform. The OCIO config must define looks for this mode to work.
