Section | |||||||||||||||||||||||||
Common Uses
The Refraction Filter Render Element is useful for changing the appearance of refractive elements, after rendering, in a compositing or image editing application. Below are examples of possible uses.
In the example, the refractions are brightened and tinted using the Refraction Filter RE. See the render before and after compositing.
Before after | ||||||||||
Underlying Compositing EquationUnderlying Compositing Equation
The Refraction Filter Render Element is multiplied by the Raw Refraction to produce the same information seen in the Refraction pass, but having them separated out allows them to be manipulated individually before combining them together. This allows for greater control over the final image.
VRayRawRefraction x VRayRefractionFilter = VRayRefraction
Fancy Bullets | ||
