Common Uses
The Shadows Render Element is useful for changing the appearance of shadowed areas in a compositing or image editing application. Below are examples of possible uses.
Column | ||
Column | ||
Column | ||
Column | ||
Column | ||
Column | ||
In the example the Shadow RE is subtracted from the Beauty element, resulting in a darker render.
Before after | ||||||||||
width | 40% |
Shadows darkened in composite using the Shadows Render Element
Column | ||
Underlying Compositing Equation
VRayRawShadow x VRayDiffuseFilter = VRayShadows
Fancy Bullets | ||
