Section | |||||||||||||||||||||||||
Example: Default V-Ray denoiser
The This example below illustrates how the Default V-Ray denoiser works after more samples are made with the Progressive image sampler. When the samples are too few, there's not enough information for the denoising to produce a smooth result. You can compare the results between an image with applied denoising and without.
Example: NVIDIA AI denoiser
The This example below illustrates how the NVIDIA AI denoiser works after more samples are made with the Progressive image sampler. When the samples are too few, there's not enough information for the denoising to produce a smooth result. You can compare the results between a render with applied denoising and without.
Example: Intel Open Image Denoise
The This example below illustrates how the Intel Open Image Denoise works after more samples are made with the Progressive image sampler. When the samples are too few, there's not enough information for the denoising to produce a smooth result. You can compare the results between a render with applied denoising and without.
Section | |||||||||||||||||||||||||||||||||||
