This page provides information on the Presets dialog.
Section | |||||||||||||||||||||||||||||||||||||||
Saving a Preset
- Type the name of the preset into the edit box in the left part of the dialogue.
- Select the roll-outs you want to save from the right part of the dialogue.
- Press the Save button. The preset will appear in the presets list. If a preset with that name already exists, it will be overwritten.
Loading a Preset
- Select the preset you want to load from the list on the left.
- Select the roll-outs you want to load from the list on the right.
- Press the Load button. The relevant parameters will be loaded from the preset. Note that you may need to open and close the Render dialogue to see the changes.
Fancy Bullets | ||
